This error message appears when other material type than Corona Outline Material is used as the global outline material in Render Setup > Scene > Object Outline.
Solution:
- Only use the Corona Outline Material as the global outline material.
Example:
Using a Corona Physical Material as the global outline material triggers the error:
There is no error message when a Corona Outline Material is used as the global outline material:
