Using Render Selected with included reflections / refractions will always clear the whole VFB
Full error message text:
Using 'Render selected' with included reflection/refractions will always clear the whole VFB to ensure correct result.
This error message appears when the following combination is used:
  • Render Setup > Scene > Render Selected (Pixel Mask) option with reflections and refractions included  is enabled
  • Render Setup > System > Clear VFB between renders option is disabled
In such scenario, Corona automatically enables the "Clear VFB between renders" option due to technical reasons. To prevent this error message from appearing, either manually enable the "Clear VFB between renders" option, or use the "Ignore similar messages" option in the error message itself.
Was this article helpful?
0 out of 0 found this helpful
