Full error message text:
3ds Max:
VFB background is active. To avoid artifacts around object edges - whether seen directly, against reflections, or in refractions - set environment overrides to black in Render Setup > Scene.
Cinema 4D:
The VFB background image is enabled, but non-GI environment overrides are not set to black. Artifacts may appear around object edges when tone mapping is used. Enable the overrides in render settings or adjust scene sky, then re-render the image.
In order to use the VFB Background feature correctly, you need to enable environment overrides for your scene and set their colors to pure black. This is to prevent artifacts, such as bright outlines, appearing around object edges when seen directly, in reflections (e.g. mirrors), and through refractions (e.g. window glass). To automatically enable the overrides, use the "Set environment overrides..." button available in the error message window.
Example
VFB Background enabled. No environment overrides used:
VFB Background enabled. Environment overrides enabled and set to black:
Environment overrides set to pure black:
In 3ds Max:
In Cinema 4d:
