This article lists error messages related to the Corona Parallax Map / Shader.
1. Bitmap's Alpha mode not set to "Image Alpha"
A bitmap used in parallax map "<map name>" does not use 'Image Alpha' as its alpha mode. The parallax layers are composited using the bitmap alpha, so they will not display correctly. Set the bitmap's 'Alpha' to 'Image Alpha'.
Solution: select the bitmap node used for the parallax effect and make sure its Alpha mode is set to "Image Alpha".
Alpha mode set to "Image Alpha" in Corona Bitmap. | Alpha mode set to "Image Alpha" in native 3ds Max Bitmap. |
2. Bitmap's UVW mapping / coordinates set to non-defaults
A bitmap used in parallax map "<map name>" uses non-default tiling, offset, or real-world scale. The parallax effect expects its texture mapped without any UV transformation, so it will not display correctly. Reset the bitmap's mapping parameters.
Solution: reset the bitmap's UVW mapping / coordinates to default values.
| Default UVW Mapping settings in Corona Bitmap. | Default Coordinates settings in native 3ds Max Bitmap. |
