This article lists Corona error messages related to Vantage and how to resolve them.
- Chaos Vantage is not installed
Solution: install Chaos Vantage
- Live link to Chaos Vantage failed. Detailed info...
or
Export to Chaos Vantage failed. Detailed info...
The "Detailed info..." part contains one of the following:
- Chaos Vantage is not installed.
- Running Vantage instance is busy
Solution #1: Make sure that in Vantage you have the option Live Link > Start Server on Application Start enabled
Solution #2: Vantage may be processing another request (possibly another live link). Wait for the request to complete or restart Vantage.
- Communication with converter process was unexpectedly interrupted.
Solution: Restart live link. If that doesn't help, restart Vantage.
- Vantage process startup timed out.
Solution: Manually start Vantage.
- Chaos Vantage did not start rendering in interactive mode as expected.
Solution: This is most likely due to a bug. Restart 3ds Max / Cinema 4D.
- Chaos Vantage is already rendering other scene with live link.
Solution: Stop the existing live link. If that doesn't help, restart Vantage.
- Failed to open file in current Vantage instance
Solution: Restart Vantage. If that doesn't help, restart 3ds Max / Cinema 4D.
- Chaos Vantage is not currently running in interactive rendering mode.
See also:
