How to make refractive caustics (water)?
Download the example scene. (Created with 3ds Max 2022 and Forest Pack 7.1.2)
What is a caustic?
Most artists think of caustics as the light that gets focused through glass or water. But, for the people in computer graphics: A caustic is any lighting contribution that goes from light source to specular (reflective or refractive), to diffuse surface, to eye (or camera).
Example of a caustic
Read more in our blogpost "What are Caustics and how to render them the right way".
Caustic solvers in V-Ray
In V-Ray, there are two ways for computing caustics - Photon mapping (old) and Progressive caustics (new).
As of V-Ray 7, Caustics (Photon mapping method) can be calculated on the GPU.
In this article, we will focus on using the Progressive caustics solver. Bear in mind that the feature is still work in progress. If you happen to find an issue, please report it. Contact Chaos Support.
Requisites
To produce caustics, generally, you need three things:
  • A refractive VRayMtl material with affect shadows turned off.
    To get accurate results, VRayMtl's "Affect Shadows" option, which is designed to create a simple caustic effect, must be turned off.
  • A light source
    For best results - a small bright light source, which  will produce sharp caustics.
  • An object to catch the caustics
Setup
In this tutorial, we will make swimming pool caustics.
  • Geometry
    We've created a pool geometry to catch our caustics and a plane for our water geometry with a VRayDisplacementMod for extra realism.
The water can be displaced via a Noise texture, but any procedural wave texture will work. Both closed (box) and open (plane) water geometries will produce caustics.
  • Materials
    For the water material, we will use VRayMtl with the Water preset. Remember to disable Affect shadows.
Location of the VRayMtl's "Affects shadows" option in 3ds Max
For the other objects, you can have any materials of your choice. You can use, f.e., the pool tiles from the Chaos Cosmos library.
  • Settings
    As the calculation method, choose Progressive (WIP). This method doesn't need much setup, except using the Progressive Image Sampler.
    Preview of the Progressive (WIP) calculation method 's location in 3ds Max
    You can modify the multiplier of the caustics in the Expert settings in case you wish the effect to be more visible.
Preview of the Multiplier's location in 3ds Max
  • Lighting
    For the light source, we'll use a VRaySun. Make sure the Photon emit radius parameter covers the whole area of the pool. The area outside of the radius will not be calculated.
Demonstration of adjusting VRaySun's Photon emit radius parameter in 3ds Max
Other small and bright light sources could also work.
  • Result
    Adjust the angle of the light so you can achieve different caustics results.
Note that for the caustics to appear, a few passes must render first.
Was this article helpful?
2 out of 2 found this helpful
