This article covers information on setting up OptiX and NVLink for usage with V-Ray. It examines their purpose and answers questions such as:
- What is NVLink and what is it used for?
- How to set NVLink?
- How does V-Ray benefit from NVLink?
- Which Nvidia driver is best for using V-Ray GPU?
- How to determine if a GPU device is compatible with V-Ray GPU?
GPU rendering has gained popularity and new methods are introduced for boosting performance, and for reducing some limitations.
This article explains the NVLink technology, the setup required for proper functioning with V-Ray and it effect on the rendering process.
What is NVLink?
NVLink is a wire-based hardware connection between GPU devices that allows multiple graphics cards to share their available memory. This is significant for GPU rendering, since it allows more memory to be used for large scenes, that otherwise would not fit on a single device.
There are different types of NVLink connectors depending on the physical space between the GPUs and whether GeForce or Quadro cards are used. NVLink can only be used to bridge identical graphics cards.
Setting up NVLink for GeForce Devices.
Requirements:
Identical GeForce devices with NVLink support;
Enabled SLI-mode from NVidia Control Panel;
SLI Ready Motherboard.
Enabling NVLink on GeForce.
Open the NVIDIA Control Panel.
Go to "Configure SLI, Surround, and PhysX".
Under "SLI configuration", select "Maximize 3D performance" and click Apply.
After you have enabled NVLink, V-Ray will be able to use it. To verify that the setup is complete, run a test render and check the V-Ray Messages Log for the following message:
NVLink Detected!
Device[0] (Quadro GV100) is using NVLink with ID: 0
Device[1] (Quadro GV100) is using NVLink with ID: 0
Number of CUDA devices: 2
Setting up NVLink for Quadro Devices.
Requirements:
Identical Quadro devices with NVLink support;
All Quadro GPUs should run in a special TCC driver mode;
Monitors should not be attached to a device that is running in TCC mode;
A dedicated graphics card should be installed for a monitor instead;
Switching Driver Mode to TCC.
Switch the driver mode to TCC through the nvidia-smi command-line utility that is installed along with the NVidia drivers. Its default location is:
C:\Program Files\NVIDIA Corporation\NVSMI
To use nvidia-smi you need to start the Command prompt. Press Start and type cmd.
Use the following command to enter the directory of the nvidia-smi tool:
cd C:\Program Files\NVIDIA Corporation\NVSMI
Use the following command to change the TCC mode:
nvidia-smi -g {GPU_ID} -dm {0|1}
Where the value for dm is either:
0 = WDDM
1 = TCC
And {GPU_ID} is the unique ID number that nvidia-smi associates with each GPU.
To view the GPU_IDs run this command:
nvidia-smi -L
The result is printed in the command prompt:
GPU 1: GeForce RTX 2080 (UUID: GPU-21600cd2-5f9f-fb16-e1dd-e45e99e85a01)
In this example, the {GPU_ID} is 1.
Sample Command:
nvidia-smi -g 1 -dm 1
To verify that NVLink is enabled, run a test render and check the V-Ray Messages Log for the following message:
NVLink Detected!
V-Ray GPU System Requirements.
Make sure your PC configuration meets the minimum system requirements to use V-Ray GPU.
CUDA and RTX requirements for V-Ray GPU:
NVidia GPU architecture requirements. Make sure that the GPU architecture meets the system requirements listed in the technical documentation.
Compute capability requirements. All NVidia GPUs have a compute capability value defined by NVidia. The value is also printed in the V-Ray Messages:
Make sure that the GPU Compute capability meets the required compute capability.
Note: The RTX engine will work with NVidia GPU(s) without RT cores that meet the system
requirements. However, it is strongly recommended to use GPUs with RT cores to
benefit from the performance boost.
Recommended NVIDIA Drivers.
V-Ray GPU performs a graphics driver check when starting the render. The V-Ray Messages Log prints a warning message if the current NVIDIA driver is different from the recommended one.
The current recommended driver can also be found on the V-Ray GPU page on our website.
Using the recommended driver provides the best V-Ray GPU experience.
