How to make Gobo Lights In V-Ray for 3ds Max
This quick tip article guides you through the process of creating a gobo/projector light effect using V-Ray Lights.
How to?
  1. Create a V-Ray Light and set its Type to “Disc”
Preview of the Type parameter's location
  1. Make the light fully directional by setting the Directional parameter to 1.0 in the light’s Plane/disc light rollout
Preview of the Directional parameter's location
  1. Plug the texture you want to project in the light’s Map slot
Preview of the Map slot's location
Rendering now, you’ll get the following result:
Preview of the result so far
Depending on the case, you might need to lower the light’s intensity to get the texture
projection visible.
You’ll also notice the gobo light has a very sharp edge, but you might want to add a bit of a falloff to make the transition smoother. The next steps show you how to do that.
  1. Open the Slate/Compact Material Editor and drag-and-drop the projection Map that’s plugged into the light’s Map slot
Preview of the dragging and dropping of the Map
  1. Create a VRaySoftbox map and plug the projection map into its Base slot
Preview of the projection map connected to a VRaySoftbox map
  1. Make sure to turn on the Base Color map in the VRaySoftbox Base parameters
Preview of the VRaySoftbox's Base color map checkbox location
  1. Plug the new VRaySoftbox map into the light’s Map slot
Preview of plugging the VRaySoftbox into the VRayLight
  1. In the VRaySoftbox parameters, scroll down to the Gradients rollout and turn on Radial Vignette
    The default Radial Vignette gradient goes from black to white, which doesn’t give us the result we are
    after. Flip the gradient colors by using the Flip checkbox.
Preview of the Radial Vignette setup
Rendering now, you'll get a nice falloff toward the edges of the projection. Feel free to adjust it as needed by tweaking the Radial Vignette Gradient Ramp of the VRaySoftbox map.
Preview of the final result
Was this article helpful?
2 out of 2 found this helpful
