Node's transformation matrix has out of bounds or NAN values
Node's transformation matrix has out of bounds or NAN values. This may be caused by an object extremely far from the scene origin. The node will be removed from the rendering. Offending node: {NODE_NAME}.
Possible solutions:
  • Move the problematic object closer to the camera you are rendering from.
  • Remove the problematic object.
Was this article helpful?
0 out of 5 found this helpful
