The installed version of Phoenix is not fully supported. The minimum supported version of Phoenix is 4.41.03.
When using older versions of Phoenix, it is possible to render all "mesh" effects and some volumetric effects, however, there are some limitations:
  • For volumetric effects, much less accurate 3ds Max atmospheric rendering mode will be always used, which results in no scattering inside the volume.
  • If the volumetric medium is emitting light, default 3ds Max light objects will be created, which are using unsupported shadow type, and this will trigger Corona Error Messages window to pop up. No shadows will be rendered from these light sources.
Solution: install the newest version of Phoenix.
Note: If you want to use Phoenix 4 - you need at least Phoenix 4.41.03. If Phoenix 5 - then, at least Phoenix 5.01.02.
See also: Volumetric FX - Known bugs and limitations
Was this article helpful?
1 out of 1 found this helpful
