Interactive rendering does not fully support the currently installed version of Phoenix. The minimum required version is Phoenix 4.41.03.
This error message means that the currently installed version of Phoenix is not fully supported by Corona interactive rendering, so the Phoenix objects will render fine, but the interactive rendering may not react to some changes of the object properties such as changing the smoke color. Manually restarting the interactive rendering is required to see the changes.
Solution: Install the recommended version of Phoenix or newer.
Was this article helpful?
0 out of 0 found this helpful
