Chaos
Back to Chaos website
Contact Support
Sign in Try Buy
Keep Enscape running smoothly. Switch to the latest version in 3 simple steps. [Update Now]
  1. Chaos Help Center
  2. FAQ
  3. Product Articles
  4. Corona
  5. Corona - General
  6. Corona Error Messages
Corona currently ignores motion blur settings of FumeFX nodes.
Updated May 30, 2023 10:03
See: FumeFX no longer supports Corona
Motion blur can be toggled in the FumeFX UI > rend tab > Motion Blur.
Motion blur of the volume data is currently ignored (blur caused by the movement of fire or smoke particles, etc.), however standard motion blur does work - for example if the FumeFX node is translated, scaled, or rotated.
See also: Volumetric FX - Known bugs and limitations
Was this article helpful?
0 out of 0 found this helpful
Articles in this section
  • Error saving AI Enhancement image
  • Global outline material can only use Corona Outline Mtl directly
  • Triangle mesh contains invalid values (NaNs)
  • An internal error has occurred causing your image to contain NaN (Not a Number) value
  • This scene contains legacy 3ds Max effects that could decrease the rendering performance.
  • This scene uses legacy (pre-v12 Update 2) map filtering
  • You are using non-standard upscale factor for IR
  • Corona and Vantage Error Messages
  • Frame buffer uses view transform set in Color Management settings. Using ACES OT with a view transform may lead to incorrect results.
  • You are rendering a sequence with history autosave enabled and history overwrite confirmation enabled.
See more
