Cannot create final autosave EXR file: [file name]
This error occurs when Corona fails to correctly save final autosave EXR file.
Possible causes:
  • You’ve ran out of free hard drive space
  • The autosave file path is pointing to a non-existent location
  • The autosave file path is pointing to a network location/removable device which is unavailable now
  • The autosave file path is pointing to a location to which the user does not have appropriate write/modify permissions
Solutions:
  • Make sure the path destination still exists
  • Make sure you have enough free space on your hard drive
  • Make sure the entered file path is reachable and can be written in/modified
See:
Was this article helpful?
0 out of 0 found this helpful
