Corona and FumeFX Error Messages
This page is related to the following two error messages:
  1. FumeFX object can only be rendered in Corona when it uses CoronaFumeFXMod modifier.
  2. The installed version of FumeFX is not fully supported.
Offending scene node: <name>
This message means that you have at least one FumeFX object in the scene and you are attempting to render it without the CoronaFumeFXMod modifier.
Solution: add a CoronaFumeFXMod modifier to each of your FumeFX objects:
A scene rendered without the CoronaFumeFXMod modifier applied to the FumeFX object. The same scene rendered with a CoronaFumeFXMod modifier applied to the FumeFX object.
Full error message text:
The installed version of FumeFX is not fully supported. The minimum required version of FumeFX is 6.0. As a workaround you can export FumeFX objects to VDB files and then render those using Corona VolumeGrid.
This message means that currently you have an unsupported version of FumeFX installed. In such case Corona will use native 3ds Max atmospheric effects to render FumeFX, which may result in incorrect, lower-quality rendering.
Solution: Install FumeFX 6 or newer.
As a workaround you can also export the FumeFX simulation to VDB format and import it using the Corona Volume Grid:
  1. Set up your simulation
  2. Open the FumeFX menu
  3. Set up the path to a folder where the resulting VDB files will be stored:
  4. Start the simulation and wait for the VDB files to be exported
  5. Remove FumeFX from the scene, or hide it
  6. Create a Corona Volume Grid
  7. Click "load from file"
  8. Browse to and select all of the exported VDB files
  9. Render
These instructions are for creating the FumeFX simulation in the same scene where it will be used. Since the simulation is saved to VDB files, you can also export the simulation from a separate scene, if needed.
See also: Volumetric FX - Known bugs and limitations
Was this article helpful?
0 out of 0 found this helpful
