"Substance” map is known to cause crashes when used with interactive rendering
This message is caused by launching Corona Interactive Rendering mode while having Substance map present in the scene.
Possible causes:
Launching Interactive Rendering mode with Substance map present in the scene
Solutions:
- In case Substance map is a priority, avoid using Interactive Rendering mode
- In case Interactive Rendering is a priority, remove Substance map from the scene
