Using “Area to render: Selected” with no selected objects in the viewport. An empty scene will be rendered.
This message appears when you set the "Area to render" feature in the Common tab of Render Setup window to "Selected", but you do not have anything selected in viewport.
Solution:
When using "Area to render: Selected", make sure you have at least one object selected in the viewport.
Was this article helpful?
0 out of 0 found this helpful
