Using VrayHDRI with IR may cause crashes
This message means that a VrayHDRI map was detected in the scene. It is known to cause problems such as crashes in interactive rendering. As a part of another renderer, the VrayHDRI map should be used only if absolutely necessary.
Solutions:
Either remove the map manually and replace it with a supported one (3ds Max Bitmap, Corona Bitmap), or use the Converter Script to have it converted automatically.
Was this article helpful?
0 out of 0 found this helpful
