Scene objects with zero scale will be ignored
This article may refer to the following error messages:
1. Corona Light with zero scale will be ignored
This message occurs when scene contains any light(s) that have zero scale. Such lights will not be rendered to ensure optimal rendering performance and stability.
Solutions:
Remove lights with zero scale from scene.
2. Geometry object with zero scale will be ignored
This message occurs when scene contains any mesh object(s) that have zero scale in at least one axis. Such objects will not be rendered to ensure optimal rendering performance and stability.
Solutions:
- Remove object(s) with zero scale from scene
- If scene relies on objects with zero scale, such as hiding objects in animated sequence to pop up at right time, you can simply dismiss this message using “Ignore similar messages” option
