High quality pixel filtering used with AI denoising or upscaling error messages
This article provides information about the error messages which appear when using the High Quality pixel filtering along with AI denoising or upscaling.
In Corona 14 and Newer
Error message text: AI denoising (OptiX/OIDN) cannot be used with the "High Quality" image filter. The filter has been switched to "Tent" automatically.
This error message appears under the following conditions:
  1. "High Quality" image filter type is set in Render Setup > System > Frame Buffer > Image filter
  2. AI denoising (either the NVIDIA or the Intel AI denoiser) is enabled in Render Setup > Scene > General Settings > Denoising
or
  2. Upscaling is enabled in Render Setup > Scene > Production Upscaling
Currently, AI denoising and upscaling cannot be used with High Quality pixel filtering due to technical limitations. In such cases, the image filter type is automatically changed to "Tent" so that the AI denoising or upscaling can be used.
In Corona 13 and Older
Error message text: Using high quality pixel filtering with AI denoising is not supported.
or
Currently, AI denoising and upscaling cannot be used with High Quality pixel filtering due to technical limitations. The pop-up message provides an option to disable High Quality pixel filtering (and keep the currently selected AI denoising or upscaling active).
This means that to use high-quality filtering, AI denoising and upscaling need to be disabled manually.
Note: The Corona Denoiser can be used with high-quality filtering without any limitations.
See also:
Was this article helpful?
1 out of 2 found this helpful
