3ds Max is configured to use incorrect gamma
This message means your 3ds Max is set up to use incorrect gamma settings. As Corona does not support non-linear workflow, having wrong gamma setup will result in worse output quality, performance problems, and unpredictable outputs when saving to different formats or using distributed rendering. You should always use the following gamma settings when working with Corona:
How to configure gamma?
Possible causes:
Gamma Value in 3ds Max Gamma and LUT preferences is set to value other than 2.2.
Solutions:
 Max 2015 and newer:
  1. In the top 3ds Max menu, go to Rendering> Color Management
  2. Select “Gamma Workflow” in the Color Management Mode tab and make sure Gamma is set to 2.2.
See:
Was this article helpful?
3 out of 5 found this helpful
