Chaos
Back to Chaos website
Contact Support
Sign in Try Buy
Keep Enscape running smoothly. Switch to the latest version in 3 simple steps. [Update Now]
  1. Chaos Help Center
  2. FAQ
  3. Product Articles
  4. Corona
  5. Corona - General
  6. Corona Error Messages
Unable to store files in the given out-of-core textures folder. FOLDER_PATH
Updated March 04, 2024 14:18
This error appears when the directory for Out-of-core textures ( 3ds Max | C4D ) is not valid, does not exist, or has no write permissions.
Solution:
Make sure you use a valid directory with correct write permission for Out-of-core textures:
  • Out-of-core Rendering for textures - 3ds Max
  • Out-of-core Rendering for textures - C4D
Was this article helpful?
0 out of 0 found this helpful
Articles in this section
  • Error saving AI Enhancement image
  • Global outline material can only use Corona Outline Mtl directly
  • Triangle mesh contains invalid values (NaNs)
  • An internal error has occurred causing your image to contain NaN (Not a Number) value
  • This scene contains legacy 3ds Max effects that could decrease the rendering performance.
  • This scene uses legacy (pre-v12 Update 2) map filtering
  • You are using non-standard upscale factor for IR
  • Corona and Vantage Error Messages
  • Frame buffer uses view transform set in Color Management settings. Using ACES OT with a view transform may lead to incorrect results.
  • You are rendering a sequence with history autosave enabled and history overwrite confirmation enabled.
See more
