This guide covers some of the most common questions and issues with the first-generation Distributed Rendering, along with instructions on how to troubleshoot and resolve them.
Before continuing, we first recommend getting familiar with the Distributed Rendering setup.
Learn more about setting up Distributed Rendering.
As of V-Ray 7, update 2, we've introduced the improved Second Generation Distributed Renering.
Distributed Rendering (DR) is a technique for distributing a single render job for a single frame across many computers in a network. This reduces render times by dividing the job into sub-tasks and assigning them to different Render Server machines. When a Render Server completes a sub-task, it sends the result back to the Workstation and can then receive new sub-tasks until all tasks are completed. Finally, the image is assembled by combining the output of all Render Servers.
A consistent setup across all machines is crucial for DR to work correctly.
Some requirements:
- All network paths, if used, must be accessible by all machines
- All machines need to run the same version of all utilized software
An inconsistent setup may lead to rendering discrepancies and the final image may be incorrect. Proper maintenance and setup integrity are vital.
Therminology
- A Workstation is a machine, from which a Distributed Rendering job is submitted
- A Render Server is a machine, to which a Distributed Rendering job is submitted
A Distributed Rendering Spawner is a V-Ray instance waiting for render jobs.
Such a DR spawner must be running on each Render Server machine participating in Distributed Rendering; There are two types of spawners.
- V-Ray DR spawner (VRaySpawner) is used in CPU distributed rendering. It starts a 3ds Max instance on the server machine that waits for render requests
- V-Ray GPU Render Server is the equivalent of a V-Ray DR spawner for when GPU rendering is used. A V-Ray GPU Render Server is a V-Ray standalone instance running in server mode that waits for render requests
How DR works
- The scene is saved in the temp folder of the Workstation machine
- The scene is transferred from the Workstation machine to all Render Server machines
- Each Render Server loads and reads the scene
- Each Render Server loads all scene assets
- Each Render Server renders the part of the image it was assigned
- Each Render Server sends the rendered pixels to the Workstation machine
- The Workstation machine assembles the final image
Common issues
Could not connect to host {IP_ADDRESS}:20204
This is a general error, which indicates that the Workstation cannot reach a Render Server at this IP address. The possible causes are as follows:
V-Ray Spawner has not been started
Ensure that a V-Ray DR Spawner is running. If the spawner should be running as a service, double-check the Windows Services.
Network/Firewall permissions
Ensure the following permissions are set up correctly:
- Incoming and outgoing communication should be allowed for V-Ray Spawner on TCP ports 20204 (for CPU Rendering) and 20206 (for GPU Rendering) on the Workstation and Render Server machines. This ensures proper data exchange between the Workstation and the Render Server.
Incoming and outgoing communication should be allowed for V-Ray Spawner on TCP port 30304 on the Render Server. This ensures proper communication between the Render Servers and the License Server.
Network configuration can be tricky. When in trouble, we recommend involving an IT specialist for troubleshooting network setups in-depth.
Autodesk Backburner is not installed on the Render Server
To function properly, V-Ray DR requires Autodesk Backburner to be installed on each Render Server. If you observe 3ds Max constantly appearing and then disappearing in the Windows Taskbar when V-Ray Spawner is launched, then most likely Backburner is not installed.
A Render Node license is not available
Each Render Server needs a Render Node license in order to participate in Distributed Rendering.
Another process is already using one or more of the communication ports
If the ports used by V-Ray are already taken by another application, then the Spawner will not be able to receive and send information. You can stop the Spawner and check if another process is occupying the same port.
Multiple V-Ray Spawners are running at the same time
Scroll to the "Multiple V-Ray Spawners running at the same time" section below for more information.
You can troubleshoot this issue easily with a simple scene. Create a few primitives, add a light and try running a DR job to determine if it succeeds or fails. Re-run the test for each item in the list of possible causes until the issue is resolved.
Make sure that the scene can be rendered locally on the Render Server machine by logging into it, launching the host platform and rendering the scene. If you are unable to render it locally, this may be an indication that the issue lies elsewhere.
“Not responding” error message
This message usually appears when:
Render Server has not finished loading yet
After starting the render server, it needs some time to fully load and get ready to receive render jobs. The “Netstat” command or the “DR check tool” can be used to check if the Spawner has finished loading and is listening for render jobs on the chosen port.
- Render Server is currently busy with another task.
Render Server is stuck on a previous job
For such cases, the “Restart servers on render end” option can be enabled to force-restart the server after the render job is finished.
Preview of the "Restart servers on render end" option in 3ds Max This option should be used carefully when submitting multiple jobs in a row. It is potentially slow, as a restart takes some time. If the second job is sent to the render server machine while the Spawner is still restarting, the server won’t be able to join the rendering until the Spawner has finished loading after restart.
Render Server has crashed and exited
This can happen if there’s a problem with starting 3ds Max, e.g. corrupt or missing 3ds Max installation. Try starting 3ds Max locally to check if it starts correctly.
- Backburner is not installed
- The username the server is running with is written with other than latin letters
This may happen if there are different versions of 3ds Max installed in the same pipeline. Currently, V-Ray does not have an out-of-the-box solution for avoiding mixed results from multiple V-Ray Spawner instances. Using such a setup may lead to unexpected results like bucket discrepancies.
If, for example, two V-Ray Spawners are running at the same time for 3ds Max 2025 and 2026, and a DR job is submitted from a 3ds Max 2026 Workstation machine, there is no way for V-Ray to determine which job should be handled by which Spawner. This is because both Spawners are using the same port number.
To avoid such issues, each V-Ray Spawner needs to be configured to use a different port number and also select the corresponding port when submitting a DR job from a Workstation. There are several ways to do that depending on how the V-Ray Spawner is launched:
If you want to use the V-Ray Spawner as a Windows Service, you can use a command to register the service and set up a port number. In the example below “20XX” needs to be replaced with the 3ds Max version used. Port 20210 is just an example and it can be any other number, preferably bigger than 20210, as lower numbers are already used by V-Ray in other cases:
Batch
sc create "VRaySpawner 20xx_20209" DisplayName= "VRaySpawner 20xXX_20209" binPath= "C:\ProgramData\Autodesk\ApplicationPlugins\VRay3dsMax20XX\bin\vrayspawner20XX.exe -port=20210"
PowerShell
New-Service -Name "VRaySpawner 20XX_20210" -DisplayName "VRaySpawner 20XX_20210" -BinaryPathName "C:\ProgramData\Autodesk\ApplicationPlugins\VRay3dsMax20XX\bin\vrayspawner20XX.exe -port=20210"
If the V-Ray Spawner is launched manually from the Start Menu, the port number can be changed from the Shortcut Properties by adding -port=20210 at the end of the Target value:
Example setup of the "Launch V-Ray DR spawner" shortcut
If the V-Ray Spawner is launched from a Command Line you can change its port by using a -port=20210 argument:
“C:\ProgramData\Autodesk\ApplicationPlugins\VRay3dsMax20XX\bin\vrayspawner20XX.exe” -port=20210
To submit the job to the correct V-Ray Spawner, the port settings need to be adjusted in the V-Ray Distributed Rendering settings on the Workstation machine:
Bucket discrepancies
There is a number of possible causes for differences in the render output from the Render Servers. As a rule of thumb, the Workstation and Render Server machines need to have identical setups, including 3rd-party plugins, access to shared locations, unified software versions and service packs, etc.
Differences in machine configurations will most likely result in rendering the scene differently, even when Distributed Rendering is not used. Some possible causes:
Inaccessible assets
All shared assets need to be accessible by all Render Servers.
A common problem with accessing assets stored on shared locations (with UNC paths or mapped drives) is caused by the V-Ray Spawner running as a Windows Service with Local System Account privileges. The Local System account is a predefined local account on Windows. It's the default account that the service uses, unless otherwise specified. The service has complete unrestricted access to local resources, but has no access to shared locations, as share permissions cannot be granted to the Local System Account. To allow the V-Ray Spawner to access network assets, the V-Ray Spawner service must be registered with a Windows Account with proper access permissions to the network shares.
This can be done from Window Services > V-Ray Spawner Properties > Log On tab:Example setup of the VRaySpawner service Log on options -
Using Mapped Drives instead of UNC paths
We recommend using UNC paths (f.e., "\\server\project\") to access network resources instead of mapped drivers (f.e., "Z:\project")
An easy solution may be enabling the “Transfer Missing Assets” option from Distributed Render Settings is a useful option when an asset cannot be accessed by the render servers.
Missing plugins or scripts
If a plugin or a script is used in the scene, it is necessary to install that plugin/script on the Render Server machines, too. Otherwise, V-Ray will not be able to render the data generated from the plugin.
Different versions of the host platform, V-Ray and other 3rd-party plugins and scripts
It’s important to use the same versions and service packs for all software, including the host platform, V-Ray and all other plugins. Different software versions have different features. If a feature used in the scene is available only in a newer plugin version and not all render servers are updated to this version, then a discrepancy will likely occur.
Incorrect V-Ray Spawner version
F.e., a render job from 3ds Max 2024 workstation is submitted to a V-Ray for 3ds Max 2025 Spawner.
Different Windows regional settings
Make sure the Windows regional settings for "Decimal symbol" and "Digit grouping symbol" have the same configuration for all machines.
The options are located under Control Panel > Region > Formats > Additional settings.
The easiest way to troubleshoot Bucket discrepancies is to find which Render Server renders differently. This can easily be done with the VRayDRBucket render element, which stores information for which Render Server rendered which Bucket. Note that the VRayDRbucket element only works with Bucket Image Sampler.
After identifying which machine renders differently, log on to that machine, start 3ds Max, load the same scene that produced errors or artifacts, and render it locally. Very often, the problem will become immediately obvious after the scene is loaded or rendered.
Render Servers join the rendering after some time
Sometimes the Render Servers join the rendering after the Workstation machine already completed a part of the image. This happens because the Render Servers join the rendering only after the scene and assets are transferred and loaded, and pre-pass calculations (like the Light Cache for example) are complete. Depending on scene complexity, asset size and Light Cache settings, this might take a while. Since the Workstation already has part of the information loaded into memory, it is always one step ahead of the Render Servers.
There are several ways to make improvements:
- Export heavy geometry objects to V-Ray Proxy (or .vrscene) files. Proxy geometry is not written to the scene file and this makes the scene size smaller, which saves render time and network transfer time
- Copy assets locally on each Render Server. This can help tremendously, especially for complex scenes with lots of assets of large size since the network transfer will be minimal.
- The Transfer Missings Assets option can be very useful, as it can re-use assets that have already been transferred and cached. In other words, all assets will be transferred to the Render Servers only once. Assets will then be cached to the Render Servers and reused. Only new or updated assets will be transferred.
- Network Speed has a significant impact on Distributed Rendering. The faster the network, the quicker V-Ray will transfer its data packages, which helps reduce render times.
Low CPU utilization with Distributed Rendering
CPU utilization can be low in some circumstances:
Using the Progressive Image Sampler and when the value for the Ray Bundle Size parameter is too small
The Ray Bundle Size determines the size of the job (or the sub-task) that the Workstation sends to the Render Servers. Lower values mean that V-Ray will send many smaller tasks, which may flood the network and the Render Servers will spend more time sending and receiving data packages instead of rendering. Higher values do exactly the opposite - the size of the packages will be bigger, which will minimize network transfer and improve CPU utilization.
Using the Progressive Image Sampler with lots of Render Servers
The Progressive Image Sampler has many advantages over the Bucket Sampler, but when it comes to Distributed Rendering, the Bucket Sampler provides superior scaling and it is the recommended sampler type for DR.
Last bucket stuck syndrome
When rendering animations V-Ray cannot start rendering the next frame before all the buckets are complete for the current one. This may slow down the whole process if there is an area of the image that requires a lot more sampling than the rest of it. As a result, one or more buckets can get “stuck” on a specific area, while all other machines are idle and waiting for those few buckets to complete. Lowering the bucket size can help in this case. Avoid using extremely low values, because this can have the opposite effect.
This has been resolved with the second generation of Distributed Rendering.
Using machines with different hardware
Although V-Ray doesn’t have any hardware limitations, it’s important to note the following:
- If a machine used in DR is a lot more powerful than the rest, this can, in theory, slow down the rendering
- If there is a difference in the amount of RAM installed on the Render Servers, it is theoretically possible that some machines with less RAM will fail to render very complex scenes
- Differences in the Windows Virtual Memory (Pagefile) settings could also cause crashing on some of the Render Nodes when rendering complex scenes requiring more RAM memory than currently installed.
The optimal number of Render Servers
It’s natural to assume that the more Render Servers there are for rendering, the faster the rendering will be. Although this is generally true, it may not always be the case. For example, if a scene is extremely large (in megabytes) and uses a lot of assets, but renders relatively quickly, it is technically possible that the first few machines to join the rendering will complete the whole image before the rest of the machines can even join.
- Although it is possible to render Animations with Distributed Rendering, it’s recommended to use Network Rendering instead, because some calculations may get calculated more than once. For example, V-Ray needs to calculate the Light Cache separately for each machine, which is less efficient than calculating it only once.
- Distributed Rendering does not require a 3ds Max license
- Distributed Rendering depends on your Network Speed.
- Distributed Render setups require some maintenance just like any other Network Rendering setup. Windows updates, for example, could disable the V-Ray Spawner service, power outages might put the machine in a boot state, etc.
- Sometimes Windows won’t work well if it hasn’t been restarted for months. Regular restarts are recommended.
- V-Ray uses the Windows Temp folder for transferring assets. If the Temp folder is never cleaned, it is possible to fill up the entire HDD, which will affect the proper functioning of DR. Regular cleaning of the Windows Temp folder is recommended.
- The Restart Servers On Render End option in the Distributed Rendering Settings can be very useful, since it automatically reboots the V-Ray Spawner after a job completes, thus will clear things up.
