This error message appears under the following conditions:
- "High Quality" image filter type is set in Render Setup > System > Frame Buffer > Image filter
- AI denoising (either the NVIDIA or the Intel AI denoiser) is enabled in Render Setup > Scene > General Settings > Denoising
or
- Upscaling is enabled in Render Setup > Scene > Production Upscaling
Currently, AI denoising and upscaling cannot be used with High Quality pixel filtering due to technical limitations. The pop-up message provides an option to disable the high-quality pixel filtering option (and keep the currently selected AI denoising or upscaling active).
This means that to use high-quality filtering, AI denoising and upscaling need to be disabled manually.
Note: The Corona High Quality denoiser can be used with high-quality filtering without any limitations!
See also:
