How to disable full VFB refreshing when using region rendering in Corona for 3ds Max?
By default, VFB will be cleared once the rendering begins. This is sometimes unwanted (for example when re-rendering a part of the image using region rendering).
To disable the VFB refreshing use the "Clear VFB in between renders" option under Render Setup > System > Frame Buffer.
Was this article helpful?
0 out of 1 found this helpful
