How to start 3ds Max with a specific version of Corona (using multiloaders with Corona 5 and newer)
Sometimes you may want to:
  • Easily switch between different versions of Corona without the need to manually copy the plugin files into the appropriate 3ds Max installation directories or re-installing Corona.
    or
  • Run two or more instances of the same 3ds Max version at the same time, each with a different Corona version.
To find out how to do it in Corona 5 or newer, see: Multiloaders at the Chaos Documentation Portal
The old guide for Corona Renderer 4 and older can be found here: [link]
Was this article helpful?
0 out of 0 found this helpful
