How to change the tooltips language in Corona for 3ds Max?
Since Corona version 1.5, it is possible to change the language of tooltips. Simply go to Render Setup > System and press the "System Settings" button at the very top of the rollout. A new "Corona System Settings" window should appear with various options, including "Tooltips Language", which you can select from the drop-down menu:
If you spot any mistake in the localized tooltips, please notify us about this.
Was this article helpful?
0 out of 0 found this helpful
