How to use the Corona Camera in 3ds Max?
Note: You are viewing an article in the Corona Help Center that covers the usage of the Corona Camera and shows practical examples. See also: Corona Camera at the Chaos Documentation Portal.
Corona Camera viewport representation.
What is it?
The Corona Camera can be used instead of the native 3ds Max cameras (Free, Target, Physical), and should be used instead of the obsolete CoronaCameraMod modifier. It can be added from the Command Panel > Cameras > Standard menu, and it features all the photographic controls that can be found in a native 3ds Max Physical Camera, plus all the Corona-specific post-processing, panorama, VR, and other options.
The Corona Camera can be created by going to Cameras > Standard. There is no separate "Corona" category. This saves you one click!
Note: The CoronaCameraMod modifier is still available in 3ds Max to guarantee backward compatibility for scenes saved with older versions of Corona. It should not be used in any other cases, though.
What are the advantages of the Corona Camera?
Environment Overrides
You can override the environment map(s) per-camera:
The above examples come from a single scene. Left - a camera using a forest HDRI as the scene environment with a reflection override enabled so that there are no tree reflections in the water. Right - another camera using a daylight HDRI as the scene environment and an evening HDRI as the reflection override.
Depth of Field
Depth of Field can be easily toggled on and off from the Corona Camera’s UI, and the focus can be set by picking any object in the scene using the Override focus > Object option. The selected object’s pivot will be used to determine the position of the focus point. This is especially useful if the focus should be locked on a moving object during animation.
Depth of field can be enabled for the Corona Camera, and the focus point can be locked to the pivot of a specific object.
Note: Starting from Corona 12 Update 1, the Depth of Field (DOF) indicator in the viewport was introduced to help visualize a camera's focus range before rendering. It displays near and far planes around the focus point, representing the in-focus area; objects between these planes will appear sharp, while those outside will blur based on the F-Stop setting.
Object Visibility
The Corona Camera has the ability to include or exclude objects in the view rendered from that specific camera. This removes the need to use the “Renderable” object property, and also allows rendering different objects from different cameras.
Specific objects can be excluded from Corona Camera's visibility. This is a per-camera setting, so you can make different objects visible and invisible for different cameras.
Interactive Rendering
As opposed to the native cameras, Interactive Rendering will not restart when changing the tone mapping parameters of a Corona Camera.
Virtual Reality and Panoramas
VR, panoramic, and fisheye projection can only be enabled when using the Corona Camera. They can be found under the “Projection & VR” rollout.
The Corona Camera features various projection modes.
Additional Features
  • You can select both the Camera and its Target at the same time by clicking on the connecting line.
  • You can see the Camera’s clipping planes in the viewport.
  • You can easily resize the Camera’s viewport icon using the Icon size option under the Viewport display rollout.
  • The camera's viewport icon changes according to the currently used VR mode (spherical, cylindrical, etc.)
Resolution Override
Starting from Corona 15, each Corona Camera can override the global output resolution set in Render Setup > Common > Output Size. This lets you assign a different resolution and aspect ratio to individual cameras in the same scene, without having to change the render settings every time you switch cameras.
The controls are found in the Overrides rollout, under Image resolution override:
Enable - turns the per-camera resolution override on. When enabled, this camera's Width and Height are used for rendering instead of the global output size.
Keep aspect ratio - when enabled, changing Width or Height adjusts the other value automatically to preserve the current aspect ratio.
Width / Height - the resolution used when rendering from this camera.
Refresh - updates the render output to match the camera's override values.
Exposure, tone mapping, post-processing and Corona Camera
Adjusting exposure, tone mapping, and post-processing options:
When rendering outside of the Corona Camera (e.g. from a free perspective view):
  • The exposure, tone mapping, and post-processing settings available under Render Setup > Camera and inside the Post tab of the Corona VFB will be always used. These settings are locked to each other, so if you change a setting in the Render Setup dialog, the same value will be used in the VFB, and vice versa.
When rendering from a Corona Camera:
  • By default, any Corona Camera uses the same settings as the perspective view (the exposure, tone mapping, and post-processing settings available under Render Setup > Camera and inside the Post tab of the Corona VFB)
  • If the "Override" checkbox is enabled in the Tone Mapping rollout of a Corona Camera, then this camera uses its own tone mapping settings. The tone mapping stack can be edited, saved, loaded, and also copied from the global settings:
  • Additional "Override" checkboxes can be enabled in the Postprocessing rollout to override bloom and glare and sharpening and blurring options:
  • To use photographic exposure based on the photographic parameters available in a Corona Camera (ISO, f-stop, shutter speed), go to that camera's Tone Mapping rollout and make sure that:
    • The "Override" checkbox is enabled
    • That camera's tone mapping stack ("Edit..." button) includes a Photographic Exposure tone mapping operator:
Saving and loading the tone mapping and post-processing settings
The Corona VFB offers Save and Load options, which can be used to save and load tone mapping and post-processing settings using the special CONF file format. These settings can be freely exchanged between the Corona VFB and the Corona Camera. This allows, for example, for:
  • Defining the look of the image using the Post tab of the Corona VFB, and then moving those settings to a Corona Camera.
  • Creating various post-processing presets, which can be then loaded into different Corona Cameras and the Corona VFB.
  • Setting up multiple Corona Cameras with different post-processing settings, and then loading those settings from one of them into the VFB.
The Corona VFB's Post tab features various tone mapping and post-processing options, and the possibility to save and load them.
After clicking the Save button, you can save your custom preset as a CONF file.
You can then load the CONF file saved from the VFB into a Corona Camera (and vice versa).
If the CONF file is loaded into the Corona Camera, and the Override checkboxes are enabled in that Corona Camera (to override the VFB settings), you will see that our custom post-processing preset is now used for the rendered image. So first we set up our desired post-processing in the VFB, then we saved it as a CONF file, and then loaded that CONF file into the Corona Camera.
If we render a non-camera view (in this case a free perspective view), only the settings available in the VFB Post tab will be considered. Once we render from the Corona Camera again, the CONF settings loaded in that Corona Camera will be used again.
See also:
Was this article helpful?
0 out of 1 found this helpful
