Enscape could not start
You could encounter a situation where Enscape isn’t starting. In some cases, there could be an error, while in other cases, you might see Enscape trying to load, only to close soon after.
The reasons for that can vary depending on what is causing it, but in a lot of cases, simply checking if everything is up to date and installing any pending updates, might be all that needs to be done. Otherwise, contacting the Enscape support team is the best course of action, as we’ll be able to review the logs and advise accordingly.
Things to check for pending updates usually include:
  • Enscape;
  • Graphics card driver;
  • Host application;
  • (Optional) CPU driver.
To help you with that, we have prepared this article, detailing the process on what you can try on your own and how to contact Enscape’s support team, should the error persist.
Was this article helpful?
0 out of 4 found this helpful
