How to convert local paths to UNC in Corona for 3ds Max?
Using UNC paths is essential to make sure that distributed rendering works flawlessly. Below is a simple guide which helps with converting local paths (C:\textures\texture.jpg) to UNC paths (\\ComputerName\textures\texture.jpg)
  1. Go to Utilities tab in 3ds Max (hammer icon)
  2. Click on "more..."
  3. Choose "Bitmap/Photometric paths" and press OK
  4. Click on "Edit Resources..."
  5. A window with all your assets visible should pop up
  6. Press "Strip All Paths"
  7. Select all your assets
  8. Press "Set Path"
  9. Point to the network location where the assets are stored
This should convert all local paths to UNC ones.
Was this article helpful?
1 out of 3 found this helpful
