How to enable the "Development / Experimental stuff" tab in Corona for C4D?
Note: This section should be accessed only in special cases, if instructed by Corona developers or tech support team, or if the user is fully aware of what you're doing.
Generally, it is not recommended to enable this section to change any settings listed there.
To enable the Development/Experimental stuff rollout:
- Go to the menu Corona > Preferences.
- Under the "Advanced" category, check the "Enable devel/debug mode" checkbox.
- Close the window and then go to Render Settings
- A new "Development/Experimental stuff" category will appear.
![]() Click to enlarge the images.
